Editing screenmakers .cs file manually
jeppe
in ScreenMaker
since i haven't got screenmaker application to show and write rapid variables properly directly, I use buttons that reads/writes the variables to application variables. i've got 4x read/write buttons which each retrieves or writes ~10 rapid variable values. Now i'd like to combine these buttons to one, and since i've done the bindings once already, i don't want to do it again.
I've tried to edit the screenmakers .cs file and copy/paste bindings, but it gets overwritten every time when robotstudio touches the files (as it is said in file itself...).
There must be a workaround for this, otherwise i'll have to do the clicking cycles ~80 more times.
Thanks for help!
1
Same question here,
