Simulation Graphic do not move
                    betaGuy
                    When I run a simulation. In my RAPID file, there is a pointer that moves correctly, but in graphic window robot isn't moveing.
All data are synchronized correctly.
            up0
            This is probably because you started RAPID execution without starting the simulation. —Maxim RiabichevPC Software Support Engineer0 —Maxim RiabichevPC Software Support Engineer0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 31 AppStudio
