Simulation Graphic do not move
betaGuy
When I run a simulation. In my RAPID file, there is a pointer that moves correctly, but in graphic window robot isn't moveing.
All data are synchronized correctly.
up0
This is probably because you started RAPID execution without starting the simulation.
