Error when creating Omnicore projekt with "customize options"
Gpe
Have anyone experienced this behaviour ?
tried to reinstall both windows and RS without change.
Running RS 2023.4.1 and Windows 10 pro
Error code below.
RobotStudio .NET exception: Method 'DisposeAsync' in type 'Microsoft.Extensions.DependencyInjection.ServiceProvider' from assembly 'Microsoft.Extensions.DependencyInjection, Version=6.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' does not have an implementation.
============================================Base exception: TypeLoadException
at RobotStudio.UI.InstallationEditor.InstallationEditorWindow..ctor()
at RobotStudio.UI.InstallationEditor.InstallationEditorCommandHandler.<LaunchWindow>d__6.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at RobotStudio.UI.Controller.TemplatesVm.<CreateController>d__45.MoveNext()
at RobotStudio.UI.Controller.CreateVcCtrl.<CreateController>d__38.MoveNext()
I am experiencing the same issue. I also can't Change Options in any of my OmniCore virtual controllers anymore. I have reached out to ABB Tech Support for some assistance. I'll post a solution if I have any success. Running Robot Studio 2024.1.10
Any updates ?
Issue seems to be:
VC not alowed to do a restore of backup ?
RobotStudio .NET exception: Adgang nægtet============================================Base exception: Win32ExceptionAdgang nægtetat RobotStudio.UI.InstallationEditor.InstallationEditorWindow.Apply(Boolean restoreBackup)RobotStudio 2024.3 (64-bit)Version 24.3.10885.0
Any updates ?Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
My issue was when I was creating a new station without using a backup.The problem with changing options was solved after installing the last RS 2024.3 Version 24.3.10885.0The error you have with backup looks like it´s about file grants/ownership
Tryed to grand default user admin rights, same error.
Have installed latest RS 2024.3 Version 24.3.10885.0Regards
Knud Erik Lindberg
Issue soved after reinstaling RS 2024.3 Version 24.3.10885.0Regards
Knud Erik Lindberg
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
