Note: Globally defined workobjects not fu
joaof
I'm using a RS5.08 and I want create a workObject. I create them but when I make the syncronisation with RSOnline, in a output window i recive a mensage "Note: Globally defined workobjects not fully supported. [5] 10-04-2007 9:35:47". In my program module it does not appear.
Regards,
Joao Fidalgo
You have to specify in the "Synch. To VC" window to what module the RS data should be synchronized. If you not specify an existing module, RS will create a new module with the name "module1" there the data will be created.
The message you got is only a warning, and can normally be ignored.
Instead of RSOnline I recommend that you use RobotStudios built in rapid editor.
Thanks!
Now it Works!
Regards,
Joao Fidalgo
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
