TCP Trace using 3DP PowerPac
cmaynard
I am wishing to use the TCP Trace feature in 3DP Printing simulations with colours set to monitor robot TCP speed (something I can't do in the 3DP powerpac process trace simulation)
The trace feature doesn't seem to work while running the code generated by the powerpac. Is there any way to make this function?
I seem to have found my own answer after posting this...
It seems 3DP moves my tooldata over to tool named t3DPActive for the duration of the print:"TCP Trace: Tooldata 't3DPActive' not found in station 09/04/2024 2:10:45 pm General
Any idea's on how to adjust the TCP_Trace to this t3DPActive tool?
Hi @cmaynard
Unfortunately, TCP Trace doesn't support the functionality you're asking for.
Perhaps you can use Signal Analyzer to get the data you're after? There's a speed signal that you can monitor if I recall correctly.
