Robot not moving on searchL
I have a RunRoutineButton that performs a searchL and intermittently the RAPID will freeze on that command and not perform any movement but also not throw any error.
I've tested the command runs when not linked to a screenmaker app and it works.
Does anyone have any information as to why this is happening?
  • Hi,
    I guess the same goes for this problem, make a regular button.
    Thus the Runroutine button is not recommended to use for routines containing movements.
