Picking-Tab doesn't appear in RS
Hey
I'm trying to use the Picking Powerpac. The installation works, but as soon as I try to start it, PickMaster opens (good), but the Picking-Tab in RS doesn't appear.
And it gives an error as follow:
System.NullReferenceException: Object reference not set to an instance of an object.
   at PickMasterPP.UI.TabPickMaster.InitTab()
   at PickMasterPP.UI.UIManager.InitRibbonTabs()
   at PickMasterPP.UI.UIManager.InitUI()
RS Version: 2023.4.1
Picking Powerpac Version: 2023.2
Release notes of Powerpac mention, that RS needs to be Version 2023.2 but shouldn't it be backwards compatible?
So does someone know how to solve it? Or where I can get RS 2023.2?
  • im having the same issue with RS 2024.1 and Picking powerpac 2023.2. Please let me know if you got a response.
