Failure to execute Flex Pendant
Flex pendant does not start at the beginning of its work and is constantly reset
To clarify:
Are you setting the program pointer to main manually?
Is it the program pointer that is being reset, if so reset to where?0 -
Hello,Have got message about an update on it the first time?☑️2024 - RobotStudio® User Group0
