Failure to execute Flex Pendant
Flex pendant does not start at the beginning of its work and is constantly reset
  • To clarify:
    Are you setting the program pointer to main manually?
    Is it the program pointer that is being reset, if so reset to where?
  • DenisFR
    DenisFR ✭✭✭
    Have got message about an update on it the first time?
