Lubrication used in gearbox
in ScreenMaker
Shall anyone share the manual of Lubrication used in ABB Robots.
Thanks & Regards
Thanks & Regards
They are not all the same. You should refer to the product manual for the particular robot you have. Also, most of them these days have the required oil for each axis on stickers for each axis. Again, not every one of them are the same.Lee Justice0
