Program pointer in not available
Hallo, I wanna ask about my problem about my robot has lost program pointer after I habe reset system, how to fix it? Thanks
  • I am making a few assumptions here... All of the code was deleted when you did the program reset. You need to have some lines for the program pointer to go to. It will need lines for each active task as well. Then you can do the pp to routine for each task and that should fix your issue.
