'Find All References' of a digital output only works within the same task
in UpFeed
'Find All References' of a variable finds every instance of the variable in the controller but using the same feature for a digital output only returns the instances within the same task. That can be very confusing. RobotStudio 2024.1.1 Premium.
Thanks for your feedback, this will be fixed in 2024.3.Johannes Weiman
RobotStudio Team, ABB Robotics0
