IRC5 XS0 power connection
I have an IRC5 M2004 controller and it came without a power cord.  I need to make one but the XS0 main 240V power connection is proprietary to ABB and I can not for the life of me find a part number. Can someone please point me towards one?
  • I would recommend looking at the following part number from Harting. I believe this is what you are referring to.
    Harting, 19 20 003 1640
    Harting, 09 12 005 2733
    Harting, 19 00 000 5184
    Fair warning. These are a PIA to wire unless you have exactly the right wire with the recommended insulation thickness.
  • Thank you! This is exactly what I needed.  My connection is 3 pin. Will it work with this 5 pin connector?
  • Yes it will. ABB is using a 5 pin connector and only wires up 3 of the pins. L1, L2 and PE. The information on this plug can be found in the manual 3HAC047138-001.
  • Thank you!
