SmartComponent - Dynamic change of PropertyBinding
Henry123
I would like to change the Property Binding of my SmartComponent and an embedded SmartComponent dynamical:
If if Input Signal is set to high, a Property Binding shall be generated/deleted. I just found the syntax to create a Dynamic Property and a Signal. But nothing about the Property Binding.
Anny suggestions?
thanks
Anny suggestions?
thanks
Hello,You can take a look how I do with my SmartComponent here:
☑️2024 - RobotStudio® User Group0
Hi DenisFR,
thanks that helped a lot.
have a nice weekend,
Henry0
- 365 IRC5
- 84 OmniCore
