start/stop welding on the fly - Lincoln
Daper
I am trying to figure out which signals to activate/deactivate in order to achieve arc establishment and inhibition on the fly. I am using a Lincoln welding source.
I have not found any documentation so far, which gives a list of such signals, neither on ABB side nor on the Lincoln side.
Does anyone have a clue ?
I feel like I have to deal with the different topics of Configuration - PROC like "Lincoln Equipment IO" / "Lincoln Arc Equipment Properties" / "Arc Robot Properties" but I am not sure how
For those who may have the same problem, in the Application Manual Arc and Arc Sensor, the flystartdata seems to be the solution0
