PCSDK 5.15 and 5.16 downloads
Hi, we need to update an older Robotware as well as PCSDK installation and go from RW5.10 in the robot to 5.15 (or possibly 5.16). But where can I download the PCSDK for these versions, they are removed from the Developer Center? It is also removed from the RobotWare installation files for these versions.
  • Maxim Riabichev
    edited August 2024
    Hello!
    PC SDK is supposed to be backwards compatible with RW5.x, so you should be using the latest version of PC SDK for RW5.x.
    (Not for S4 controllers)
    Maxim Riabichev
    PC Software Support Engineer
  • Ok that is good information!
    And what version is that exactly? I have a hard time following the documentation on this topic.
    Is that "PC SDK 2024.2"?
