open a RobotWare 5.61 backup in RobotStudio
I have a robot with RobotWare 5.61.04 and I would like to open a backup from it in RobotStudio 2024.2.1. However this particular RW version is not available under the Add-in tab.
I'm sure this is a well known an solved problem but I can't find a solution for it here on the forum. Could someone point me in the right direction on how to get this to work?
Thanks !
Contact your country's ABB Robot Tech Support and make a request.1
I did. They sent me the installation files for mo RW version.SomeTekk said:Contact your country's ABB Robot Tech Support and make a request.
Thanks!0
