Error when creating Omnicore projekt with "customize options"
Gpe
Have anyone experienced this behaviour ?
tried to reinstall both windows and RS without change.
Running RS 2023.4.1 and Windows 10 pro
Error code below.
RobotStudio .NET exception: Method 'DisposeAsync' in type 'Microsoft.Extensions.DependencyInjection.ServiceProvider' from assembly 'Microsoft.Extensions.DependencyInjection, Version=6.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' does not have an implementation.
============================================Base exception: TypeLoadException
at RobotStudio.UI.InstallationEditor.InstallationEditorWindow..ctor()
at RobotStudio.UI.InstallationEditor.InstallationEditorCommandHandler.<LaunchWindow>d__6.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at RobotStudio.UI.Controller.TemplatesVm.<CreateController>d__45.MoveNext()
at RobotStudio.UI.Controller.CreateVcCtrl.<CreateController>d__38.MoveNext()
I am experiencing the same issue. I also can't Change Options in any of my OmniCore virtual controllers anymore. I have reached out to ABB Tech Support for some assistance. I'll post a solution if I have any success. Running Robot Studio 2024.1.10
Any updates ?
Issue seems to be:
VC not alowed to do a restore of backup ?
RobotStudio .NET exception: Adgang nægtet============================================Base exception: Win32ExceptionAdgang nægtetat RobotStudio.UI.InstallationEditor.InstallationEditorWindow.Apply(Boolean restoreBackup)RobotStudio 2024.3 (64-bit)Version 24.3.10885.0
Any updates ?Regards
Knud Erik Lindberg
Danrobotics0 -
My issue was when I was creating a new station without using a backup.The problem with changing options was solved after installing the last RS 2024.3 Version 24.3.10885.0The error you have with backup looks like it´s about file grants/ownership
Tryed to grand default user admin rights, same error.
Have installed latest RS 2024.3 Version 24.3.10885.0Regards
Knud Erik Lindberg
Danrobotics0 -
Issue soved after reinstaling RS 2024.3 Version 24.3.10885.0Regards
Knud Erik Lindberg
Danrobotics0
