what is the rapid code to start the signal analyzer record during the procedure automatic? thanks
I would like to know if it is possible to set a start record rapid code for the signal analyser
I am interested in this functionnality too. Is there any way do achive this ?0 -
The only way that comes to mind is to use RobotStudio SDK and start both RAPID execution and Signal Analyzer recording. But I haven't done this myself so I don't have any sample code to share, unfortunately.
Too bad... Thank you very much for quick response though.
If any one knows more about it for an irc5, any suggestion would be appreciated0
