what is the rapid code to start the signal analyzer record during the procedure automatic? thanks
I would like to know if it is possible to set a start record rapid code for the signal analyser
  • Hello,
    I am interested in this functionnality too. Is there any way do achive this ?
  • The only way that comes to mind is to use RobotStudio SDK and start both RAPID execution and Signal Analyzer recording. But I haven't done this myself so I don't have any sample code to share, unfortunately.
    Maxim Riabichev
    PC Software Support Engineer
  • Too bad... Thank you very much for quick response though.
    If any one knows more about it for an irc5, any suggestion would be appreciated
