AC 800M Ip configuration
Hello, I am new here on this forum. I have a question about the AC800M controller. When I try to open the IP Config software, I get this message.
Communication ports are already opened by IP configurator or other applications.
Does anyone have any ideas on how to solve this issue?
hello friend, do you have the solution? greetings from Chile
1 -
I'm facing same problem...can anyone help??0
