Error when creating Omnicore projekt with "customize options"
If I create the system without "customize options" it starts, but the function modify options in the controller tab doesnt work.
Have anyone experienced this behaviour ?
tried to reinstall both windows and RS without change.
Running RS 2023.4.1 and Windows 10 pro
Error code below.
RobotStudio .NET exception: Method 'DisposeAsync' in type 'Microsoft.Extensions.DependencyInjection.ServiceProvider' from assembly 'Microsoft.Extensions.DependencyInjection, Version=6.0.0.0, Culture=neutral, PublicKeyToken=adb9793829ddae60' does not have an implementation.
Base exception: TypeLoadException
   at RobotStudio.UI.InstallationEditor.InstallationEditorWindow..ctor()
   at RobotStudio.UI.InstallationEditor.InstallationEditorCommandHandler.<LaunchWindow>d__6.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at RobotStudio.UI.Controller.TemplatesVm.<CreateController>d__45.MoveNext()
   at RobotStudio.UI.Controller.CreateVcCtrl.<CreateController>d__38.MoveNext()
  • I am experiencing the same issue. I also can't Change Options in any of my OmniCore virtual controllers anymore. I have reached out to ABB Tech Support for some assistance. I'll post a solution if I have any success.  Running Robot Studio 2024.1.1
  • Any updates ?
  • Issue seems to be:
    VC not alowed to do a restore of backup ?
    RobotStudio .NET exception: Adgang nægtet
    Base exception: Win32Exception
    Adgang nægtet
       at RobotStudio.UI.InstallationEditor.InstallationEditorWindow.Apply(Boolean restoreBackup)
    RobotStudio 2024.3 (64-bit)
    Version 24.3.10885.0
    Any updates ?
    Regards
    Knud Erik Lindberg
    Danrobotics
  • My issue was when I was creating a new station without using a backup.
    The problem with changing options was solved after installing the last RS 2024.3 Version 24.3.10885.0
    The error you have with backup looks like it´s about file grants/ownership
  • Tryed to grand default user admin rights, same error.
    Have installed latest RS 2024.3 Version 24.3.10885.0
    Regards
    Knud Erik Lindberg
    Danrobotics
  • Issue soved after reinstaling  RS 2024.3 Version 24.3.10885.0
    Regards
    Knud Erik Lindberg
    Danrobotics
