Auto mode error when starting arcpack [ArcWelding PowerPac]
Hello, when i start arcpack from the process menu i have been getting an error popping up:
": Not able to set the controller in auto mode retry operation"
IN the output window i am getting " ForceControllerToAutoMode Failed:   The NetScanID is no longer in use. Controller removed from list.    26/04/2007 11:09:50 AM"
Does this make any sense to anyone?
"Argon Technology - your industrial robotics and automation partner, helping you build your tomorrow"
  • I restarted the computer and it seemed to of fixed things.
    The old restart the computer trick!
  • Hi Cole
    I get this message often if i am using the flecpendan.
    When i set the flexpendant in automode and the start Arcweldpowerpack this message appears.
    i then save the station and restart the station again.
    Kent Zibrandtsen
    Dept manager robot welding
    Kez@hardi-international.com
