IRC5 Controler - USB Port disable
I recently reached out ABB tech support with this same question. They told me that there is no software lock available. If I wished to disable the USB port, I should physically disconnect it from the back side.0
How can I disable the USB port on the FlexPendant?0
Hello,You can use physical USB port locks.☑️2024 - RobotStudio® User Group0
Yes, I know that. But I want this Port with software locked.
ABB tech support told me that there was no software lock available for the flex pendant either1
- 303 PowerPacs
- 353 IRC5
- 849 RAPID Programming
- 25 AppStudio
