IRC5 Controler - USB Port disable
I wonder how I can software lock the USB port on the IRC5 controller?
  • I recently reached out ABB tech support with this same question. They told me that there is no software lock available. If I wished to disable the USB port, I should physically disconnect it from the back side.
  • How can I disable the USB port on the FlexPendant?
  • Hello,
    You can use physical USB port locks.
  • Yes, I know that. But I want this Port with software locked.
  • ABB tech support told me that there was no software lock available for the flex pendant either
  • @sbrown1 Thanks for informations.  ;)
