Synchronize button in same postion on all tabs on the ribbon
in UpFeed
Is it an idea to place the synchronize button always on the same location, no matter what tab you are on the ribbon? For example always in the right corner? Or something else more consistent?
The problem is that the sync button on the Home-tab is on the middle and on the RAPID-tab it's on the left and on the other tabs it's missing. I'm always looking for the button...
1
You can add your own Quick-Access buttons.
Press here to open settings:
Move Synchronize to the left panel from the rapid tab.
Access the feature here from any tab/view:
☑️2024 - RobotStudio® User Group2 -
This totally helps! Thanks for the tip
