Moving in the opposite direction, stopping midway and returning to the starting point
Jarramy
Jarramy
edited December 2024 in RAPID Programming
I'm new to RobotStudio. I am sitting on a task that involves the reverse movement of the robot, i.e. it follows a given path, the operator presses the button and the robot returns back to the point from which it left, but as soon as it presses it continues to move along the original path. I implemented the return to the original point. As well as the return to the continuation of the path is implemented. But I don't understand how to interrupt the movement already in the interception procedure.
The code that I wrote:
TRAP reverseMove
        StopMove \Quick;
        p := CRobT(\Tool:=tool0);
        StorePath;
        ClearPath;
        MoveAbsJ Targets{Stage - 1},
v500, z50, tool0;
        MoveJ p, v500, z50, tool0;
        RestoPath;
        StartMove;
ENDTRAP
CONNECT ROB1_path_reverse WITH reverseMove;
ISignalDI TES_PP, 1, ROB1_path_reverse
Thank you in advance for any help!
Post edited by Jarramy on
  • Read up on the Pathrecorder instructions.
    Lee Justice
  • Greetings, I appreciate your attention. However, the question of stopping in the middle of the path remains unresolved in interrupting.
