Local origins
Hello.
I'm trying to create a tool but I'm having some problems with local origins of body parts.
In the screenshot, the body parts are highlighted, but they all have an origin point away from the actual object. First screenshot is showing several body parts, second is only showing a single body part. In the third screenshot, the local origin of the part is set correctly, however I would like the origin of the individual body parts to be set correctly.
Can I move the origin point for the individual body parts or does it even matter?
  • Hello,
    No, you can't change Part's Body origin. Only Part have origin.
    How did  you import your Geometry file? And which type of file is?
  • Hello @DenisFR
    I imported the geometry using the "Import Geometry - Browse for geometry" option and as a .stp file.
    I realize i forgot to upload the photos too, so I'll do that now too.
    Im unsure how to upload them, so they're hosted here: https://postimg.cc/gallery/CZfWvKk
  • Can you open your file with an other software like FreeCAD and you'll probably see that it is your Step export that is wrong.
