[Wish] Tab closing features
Tompanhuhu
in UpFeed
1. I would like a option to "Close all but this", where I can leave the selected tab open but close everything else not only editor windows but also configuration, io windows, eventlog and so on is closed.
2. I would like for this option to also be available for other tabs (Not only editor)
3. I would like a option "Close all IO windows" or "Close all configuration windows" and so on.
☑️2024 - RobotStudio® User Group
2
BumpSystemintegrator - Web / C# / Rapid / Robotstudio
Good idea. Just like TIA portal.
David
This feels like a pretty simple measure to simplify life for many who use robotstudio. Why can't this be prioritized instead of all the other new flashy features you release?Systemintegrator - Web / C# / Rapid / Robotstudio
Hello,Or at least close Tab with a center click like a lot of IDE does nowadays.☑️2024 - RobotStudio® User Group0
Or a ctrl + w and ctrl + shift + t, like in browsers!
Post edited by Maxim Riabichev on—Maxim RiabichevPC Software Support Engineer0 -
I'll see what I can do with this one.
A small follow-up on this request: It will be possible to close "all but this" tabs, and closing tabs with middle mouse button in RS 2025.3—Maxim RiabichevPC Software Support Engineer0
Maxim Riabichev said:A small follow-up on this request: It will be possible to close "all but this" tabs, and closing tabs with middle mouse button in RS 2025.3
Will "all but this" close configuration and IO windows?
Will this option be available on these tabs aswell?
I just found out that yes, it will work for configuration and IO windows.
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
