multimove
I need an idea for a code to run two functions run at the same time in RAPID. Any ideas?
MODULE Module1
 CONST robtarget Target_30:=[[1645.421406637,0,1697.500079305],[0.500000013,0.000000009,0.866025396,0.000000005],[0,-1,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
 CONST robtarget Target_40:=[[1854.035021987,0,1697.499975767],[0.50000002,0.000000009,0.866025392,0.000000005],[0,-1,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
 VAR num a:=0;
 PROC main()
 Independant;
 Path_10;
 PROC Independant()
 ActUnit MTD_500_M2009_REV1_;
 FOR i FROM 1 TO 10000 DO
 IndAMove MTD_500_M2009_REV1_,1\ToAbsNum:=a,90\Ramp:=100;
 a :=a + 90;
 ENDFOR
 PROC Path_10()
 MoveL Target_30,v1000,z100,tool0\WObj:=wobj0;
 MoveL Target_40,v1000,z100,tool0\WObj:=wobj0;
 ENDMODULE
  • If your robot has the option multi tasking, you can set the external axis to be controlled by a secondary task. That would let you have both items move independantly.
    I believe that you also have to have the MultiMove option installed.
    Good job.
