Moving Wobj by Robtarget
Dzmitry
Can you elaborate some more please? Is it really just one point or are you talking many points? Is wobj_2 exactly the same as wobj_1 or different?Lee Justice0
Yes, it's just one point.
wobj_2 is not the same as wobj_1.0 -
I have not tested this but basically this is a matrix equation.
Both poses have in common that they end up in the same pose wrt to the robot base.
So P2 in wobj2 = P1 in wobj1
PoseMult(Wobj2.pose,P2.pose) = PoseMult(Wobj1.pose,P1.pose)
PoseMult(PoseMult(Wobj2.pose,P2.pose),PoseInv(P2.pose)) = PoseMult(PoseMult(Wobj1.pose,P1.pose),PoseInv(P2.pose))
this is what I am unsure about, does the left side equal wobj2 now?
Wobj2.pose = PoseMult(PoseMult(Wobj1.pose,P1.pose),PoseInv(P2.pose))
Try it out!1 -
guillaumebatun said:I have not tested this but basically this is a matrix equation.
Try it out!0 -
I tried this code, guillaumebatun, and it's working. Thanks a lot for the tip!0
Try it out!0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
