Exporting the data from an array
Hello, I'm new to robot studio and the programming language rapid.
I have created a distance measurement for my robot's tcp and have put the data in an array. The only way I know to access it is from the flexpendant.
But is there any way to export the data in my array? I would like to analyse it in a different program.
  • Hi ...
    You can export to a file.
    Look in the help for the Open function.
    With it you can create, write, add content...
    This is a good start.
    Here is a small example:
        ! FUNCTION TO RETURN THE PATH OF THE NEWLY CREATED FILE ##################################################### 1.0 ####
        !       The FileNew function creates a new file with a specific name in the specified directory or in the default directory, depending on the conditions. If the file already exists,
        !       the function does nothing and returns the complete file path. If file access errors occur, they are handled in the error handling block.
        !       This function is designed to create a new file in a specified directory or in the default directory (HOME:), if the file does not exist.
        !       The variables 'fileIodevL' (file handle), 'pathL' (directory path), and 'isDirectoryOrFileL' (checks whether it is a directory or file) are used for
        !       data manipulation.
        !       The function checks if the parameter 'directoryPathP' (directory path) is provided. If provided, it checks if it is an existing directory using the
        !       'IsFile' function with the 'Directory' option. If it does not exist, it creates the directory and constructs the directory path (if provided) with a slash ("/") in the variable 'pathL'.
        !       It also checks if the file with the name 'fileNameP.conf' exists in the specified directory (pathL). If it does not exist, it creates it using the file handle 'Open'
        !       with the 'Append' option. After creating the file, it is immediately closed with 'Close' so that it can be manipulated by another function.
        !       The 'typeP' corresponds to the type of file to be saved. By default, saved files are of type '.data'.
        !       If the file was successfully created, the function returns the complete file path (pathL+fileNameP+typeL). Otherwise, it returns an empty string.
        !       There is an error handling block that specifically deals with the error 'ERR_FILEACC'. This error may occur if there is a file access issue. If this
        !       error occurs, the function will attempt to proceed to the next instruction using the 'TRYNEXT' command. This error usually occurs when attempting to open a non-existent file.
        ! PARAMETERS:
        !   \string directoryPathP: If provided and it does not exist, creates the directory; otherwise, it just sets the path to it. If not provided, defaults to 'HOME:\'.
        !   string fileNameP: Name of the file to be saved.
        !   \string typeP: If provided, this type is used to save the file. By default, it saves as '.data'.
        ! RETURN:
        !   Returns the file path.
        ! USAGE EXAMPLE:
        !   MODULE ModPRG()
        !       VAR string directoryPathP;
        !       VAR string fileNameP;
        !       VAR string typeP;
        !       PROC main()
        !           directoryPathP:="TEMP"
        !           fileNameP:="Parameter";
        !           typeP:=".sys";
        !           TPErase;
        !           TPWrite FileNew(directoryPathP:=directoryPathP,fileNameP\typeP:=typeP);     ! >> ~ "TEMP/Parameters.sys"
        !           TPWrite FileNew(fileNameP\typeP:=typeP);                                    ! >> ~ "HOME/Parameters.sys"
        !           TPWrite FileNew(fileNameP);                                                 ! >> ~ "HOME/Parameters.data"
        !       ENDPROC
        !   ENDMODULE
        ! LIMITATION:
        !   The input parameters "\string directoryPathP", "string fileNameP" and "\string typeP" are limited to 80 characters.
        FUNC string FileNew(\string directoryPathP,string fileNameP\string typeP)
            ! ## ATTRIBUTES ##############################################################################
            VAR iodev fileIodevL;
            VAR string pathL:="";
            VAR string typeL:=".data";
            ! Checks for the existence of the DIRECTORY; if it does not exist, creates one in HOME:\ ...
            IF Present(directoryPathP) THEN
                MakeDir directoryPathP;
                pathL:=directoryPathP+"/";
            ENDIF
            IF Present(typeP) typeL:=typeP;
            ! Create file ...
            Open pathL\File:=fileNameP+typeL,fileIodevL\Append;
            ! ###### Writes your file ...
            ! If the file is open then insert a line at the end of the file ...
            Write fileIodevL,CDate()+"; "+CTime()+"; FILE;";
            Write fileIodevL,"----------; --------; ------------------;";
            Write fileIodevL,"... TEXT ...";
            Write fileIodevL," ";
            ! Close file
            Close fileIodevL;
            ! If the file was created, returns the path; otherwise, returns empty
            IF IsFile(pathL+fileNameP+typeL\RegFile) THEN
                RETURN pathL+fileNameP+typeL;
            ELSE
                RETURN "";
            ENDIF
        ERROR
            ! POSSIBLE ERROR HANDLING
            ! If an error is encountered, proceed to the next instruction ...
            IF ERRNO=ERR_FILEACC THEN
                TRYNEXT;
            ENDIF
        ENDFUNC
    Good Work.
  • You want to analyze it in a different rapid program?
    Lee Justice
  • No I want to analyze the distance measurement in matlab
