Deployment failed message
When I try to deploy an interface to my virtual controller I get message that says "Deployment failed". How can I fix this?
  • YvoK
    YvoK
    Answer ✓
    I solved this issue by deleting the virtual controller and after that deleting the project. I created a new project and virtual controller and it's working fine now. I still don't know what the problem was with the old virtual controller
  • Could you share the detail error logs, or you can directly contact the AppStudio support team through this Survey (this channel is also in the AppStudio Help page)
