Barcode Scanner connect via com part RS-232
sb4390
I would like to connect a barcode scanner directly (no plc) via a com port (RS232) to read job part numbers.
could anyone tell me how to setup the port and the group input please?
I assume I will need to use a barcode scanner that supports serial and socket communication?
Can someone clarify the setup for Socket Data communication? Or point me to the correct manual?
- 367 IRC5
