RobotStudio event
Argument error
Hi, I have got a problem with one of the robots on site ( IRC5 M2004)
I originally got an axis revolution counter is not updated, so I carried out a recalibrate all the axis to the marks on each axis.
The robot then started moving again but now some of the positions are out a bit.
The robot runs in auto but when in manual and I try and step through the program to get to the position I want to modify I get an argument error - orientation definition error in topoint.
How come this is an issue in manual but not in auto?
  • Hi...
    Can you send me the code snippet so we can analyze it?
    Good Job
  • lemster68
    lemster68 ✭✭✭
    You said recalibrate which sounds like you fine calibrated.  Is that what you did or did you update rev counters (what you should have done.).
    Lee Justice
  • MoveJ pPickPre, vUser_Mid, z10, toolGripper\WObj:=wobjDrum_Conv;
    MoveL pPick, vUser_Lo, fine, toolGripper\WObj:=wobjDrum_Conv;           !Pick position - close gripper + add load of drums
    Gripper_Close;
    GripLoad loadDrums_x2;
    MoveL pPickPost1, vUser_Lo , z10, toolGripper\WObj:=wobjDrum_Conv;  !Motion with load - confirm pick after suitable delay
    MoveL pPickPost2_Taught, vUser_Mid, z200, toolGripper\WObj:=wobjDrum_Conv;
    MoveJ pPickPost3_Taught, vUser_Mid, z200, toolGripper\WObj:=wobjDrum_Conv;
    IF bPick_Is_A = TRUE THEN
                !Set pick confirmation flag for A position
        SetDO\SDelay:=fPick_RTN_Delay, dp_doPICK_A_RTN, 1;
            ELSE
                !Set pick confirmation flag for B position
                SetDO\SDelay:=fPick_RTN_Delay, dp_doPICK_B_RTN, 1;
            ENDIF
            MoveL pPlacePre2, vUser_Mid, z50, toolGripper\WObj:=wobjPllt_Conv;
    MoveL pPlacePre3, vUser_Mid, z10, toolGripper\WObj:=wobjPllt_Conv;
    WaitDI dp_diSpare_1, 1;
    MoveL pPlace, vUser_Lo, fine, toolGripper\WObj:=wobjPllt_Conv;
              !Place position - open gripper + set load back to empty gripper
    Gripper_Open;
    GripLoad load0;
    MoveL pPlacePost1, vUser_Lo, z1, toolGripper\WObj:=wobjPllt_Conv;
    MoveL pPlacePost2, vUser_Lo, z10, toolGripper\WObj:=wobjPllt_Conv;
    MoveL pPlacePost3, vUser_Lo, z10, toolGripper\WObj:=wobjPllt_Conv;
    ConfL\Off;
    MoveL pReturnHome1, vUser_Hi, z200, toolGripper\WObj:=wobjPllt_Conv;
                !Set place confirmation flag for A position
        SetDO\SDelay:=fPlace_RTN_Delay, dp_doPLACE_A_RTN, 1;
            ELSE
                SetDO\SDelay:=fPlace_RTN_Delay, dp_doPLACE_B_RTN, 1;
            ENDIF
    MoveL pReturnHome2, vUser_Hi, z200, toolGripper\WObj:=wobjDrum_Conv;
    MoveL pReturnHome3, vUser_Hi, z50, toolGripper\WObj:=wobjDrum_Conv;
    ConfL\On;
    MoveJ pHOME, vUser_Hi, fine, toolGripper\WObj:=wobjDrum_Conv;
  • when i try and move to the top line is when i get the error, but runs in auto.
