webware and system modules [WebWare SDK]
There is no method in Webware SDk to list the system modules, you need to know the names of the modules.
An alternative is to do a backup and analyze the file backinfo.txt which should contains the list of modules or may be analyzing the configuration files.
Axthor
- 5.4K RobotStudio
- 383 UpFeed
- 14 Tutorials
- 11 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 733 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
