Downloaded ControllerKit but it does not show up.
in AppStudio
The downloaded controller kit or any component kit does not show up when you try to open them in a project. Am I missing something or is it a bug?
I think you can try the following method
- You can exit the current project and reopen it, and then try to see if the downloaded package can be displayed
- If method 1 does not work, exit the AppStudio software and try again?
If none of them work, I think this is a BUG, welcome to report your issue through Survey (this channel is also in the AppStudio Help page).0 -
yitong said:I think you can try the following method
Hello Sorry for the delayed response.
Tried both the methods you mentioned but was unable to enable the kit; it does not show up in the list of kits.
Resolved the issue by exporting the file from a colleague, then it showed up. I shall report the issue through the survey channel as well.
Thank You!0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
