Ths TSP limit the speed of robot or only monitors the speed?
in IRC5
Hello, i have a question,
i define two TSP which it be activated with 2 different signals profisafe so my question is:
The fuction TSP of safemove, only monitors the speed of robot and if the robot Exceeds the velocity configure of TSP this fuction stop the robot or the fuction of TSP limit the speed of robot to the robot dont can exceeds the speed configure,
thanks
thanks
Hallo, according to the safemove manual, TSP is not a limitation but a monitoring of speed.So is the speed in the defined points is exceeded, a stop will be generated.0
i want to do limit the speed of robot to 30% or 70% via profisafe according to the signals, but i dont want use the rapid commands, only safemove or I/O commands0
There is a system input signal Limit Speed which you can use to reduce axis or tcp speed defined with Rapid commands SpeedLimAxis/SpeedLimCheckPoint. Maybe you can connect the input signal with your safety controller.0
okey, but if a want limit speed of robot and the track, only i can do by code use speedlimaxis no?? because in the safemove dont exist any way no?0
if i use this code, i will have the operation which i want?if VelRedNoColindante=1 AND VelRedColindante=0 THENSpeedLimCheckPoint 1400;ELSEIF VelRedColindante=1 THENSpeedLimCheckPoint 600;ELSEIF VelRedNoColindante=0 AND VelRedColindante=0 thenSpeedLimCheckPoint 2000;endif
i want to limit the speed of tcp according to the 2 signals0 -
so, with the code wich i past before, this reduce of speed is no automally, i need that it is inmediate with the signals are activated, so i need do this with safemove or the other way0
Hallo, to have an immediate effect, you should define SpeedLim..., but use the system input "LimitSpeed" to switch this on or off. You can use SafeMove or an interrupt to activate "LimitSpeed".Then the switch works independently from your Rapid code.0
yes, when is a only signal with a one speed reduce yes, because i activate the signals with the safemove and with the system input i reduce the speed.
but now, i need do it with 2 signals and 2 speed reduce, 600mm/s and 1400 mm/s.
But the reduce of speed, must activated inmeadly,because the program is very large and the speed dont can wait the cycle of robot0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
