Description/manual page entry for own Proc/Func inside Shared Modules
Runesmacher
edited August 2023 in UpFeed
I'm looking to create a sort of library for standard functions for our company to use in multiple robot applications.
I would like to make these inside a shared module, so all task can access these functions.
Since the software in a shared task is not visible in robotstudio, is there a way to:
  1. Show a short description when hovering over the function in light gray as "Update speed override for ongoing movement" when hovering over SpeedRefresh?
  2. Add a maual page entry so we can press F1 on a function to get its info?
One way that could also make it better is to allow Robotstudio to view/edit a shared module.
Thanks in advance ;)
  • bump
    If I helped, please press Vote Up  :smile:
  • bump
  • DenisFR
    DenisFR ✭✭✭
    UP
  • Hello there,
    Please elaborate on the second point. Who should be creating these manual entries, for which functions, and how should RobotStudio know that there is a manual entry for the given function? (or am I not understanding something?)
    Maxim Riabichev
    PC Software Support Engineer
  • DenisFR
    DenisFR ✭✭✭
    edited August 2023
    1. RAPID code interpreter know where Func/Proc are defined. It can look one line forward if there is a comment block and use it.
    2. We can define a special comment Format in code to define which file to open like:
    !!HelpFile: /a_relative_path_to_help_file/helpfile.html#anchor_name
    EDIT: And if RS can do like this MsCode extension:
    Post edited by DenisFR on
  • Okay, thanks.
    I'll run this by R&D and see what they say.
    Maxim Riabichev
  • This would be great.
  • bump
  • bump
  • Tompanhuhu
    Tompanhuhu ✭✭✭
    bump
  • bump.
    Any updates on this? Pretty neat feature to have.
  • Sorry guys, I've been swamped with other tasks and haven't had the time to check on this topic yet.
    I'll try to squeeze it in asap!
    Maxim Riabichev
  • I have forwarded this feature request to the Product Manager of RobotStudio.
    I'll keep you posted on any developments.
    Maxim Riabichev
