IRB 6700 and IRBT 7004 setup yields no RobotWare version - why?
BenBie
when setting up a virtual controler for the IRB 6700 and a IRBT 7004, from Layout, there is no RobotWare version in the "Select Mechanisms and RobotWare" section being recommended. Why is that? Is there a way to work around this?
Thank you,
Kind regards
Thank you,
Kind regards
Select IRBT6004 instead of 7004 for IRB67000
