Controller found but unable to connect - Virtual Controller
Hi , I am facing an issue with connection the iot gateway to the virtual controller
- I check the firewall setting : all are off
-  Abb virtual controller service is running
- i can connect the server but not the controller
- i am using VM
  • Do it mean that IoT Gateway is running on VM but RobotStudio is not?
  • Both the Robot studio and the Iot Gateway on the VM , also in the VM i used the unlicensed version of robot studio
  • What is the version of RobotWare for the virtual controller?
  • Version 6.16
  • Do you include the following 2 options inside the system of your VC?
    (1) 616-1 PC Interface
    (2) 1582-1 IoT Data Gateway
