Is it possible to put routines in a queue?
JTO
First of all, I'd like to apologize in advance. I'm no stranger to writing programs (particularly welding) on ABB robots but I'm unfamiliar with the more advanced stuff. We just got a new setup that I'm quite unfamiliar with and would like some help with the more advanced features.
The new welding setup is 2 welding robots on a singular track spanning between two seperate cells. The parts being welded are triple pass so my question is this. Because there will be intermittent pass cleaning performed by the operator, is there any to put the routines into a queue so the robots are able to move between the two modules (each cell is a seperate part)? For example if one cell requires cleaning by the operator before continuing, (example being first pass is done on one part but the other cell is ready) is it possible to write a complex series of conditional statements to keep the routines in order while the robot goes between the cells and modules? Or would it simply be easier to have the operator load the routines manually
Apologies in advance as I'm sure the answer is quite simple but I'm new to the advance side of programming and will happily take any advice
Best Answers
The first thing that comes to mind is that you might want to do a call by variable. You would have to do some logical operations to determine what is next in the queue. Then, the format is either %name_of_the_routine_here% or CallByVar "routine" ,reg1; You should also study up on what is called late binding.Lee Justice0
Two technical reference manuals, first, Rapid overview. The second, Instructions, functions and datatypes.Lee Justice0
lemster68 said:The first thing that comes to mind is that you might want to do a call by variable. You would have to do some logical operations to determine what is next in the queue. Then, the format is either %name_of_the_routine_here% or CallByVar "routine" ,reg1; You should also study up on what is called late binding.0
The easiest way I've found is to download Robot Studio from ABB's website, install it, then go to the addins tab and download the RobotWare for OmniCore or IRC5 (depending on what you have), then after that go to File -> Help -> OmniCore/IRC5 Documentation. In there you will see "RAPID Instructions, Functions and Data Types", "RAPID Overview", as well as "RAPID Kernel".
In those three you can do a search for "late binding". There aren't very many examples, but it's also not that hard.Example 1:
% "proc" + NumToStr(product_id, 0) % x, y, z;
Example 2:
VAR string procname {3} := ["proc1", "proc2", "proc3"];
% procname{product_id} % x, y, z;
I like to use RMQ and just send the command to the same task or can be called from another task or device if you have the options for that. This will stack up a queue of procedures that will be ran one after another.
example, would stack up two programs then run the two programs then wait forever.RMQ_PROC:="Program1";RMQSendMessage RmqRobSlot, RMQ_PROC;RMQ_PROC:="Program2";RMQSendMessage RmqRobSlot, RMQ_PROC;WHILE TRUE DO
RMQReadWait MyRmqMsg \TimeOut:=WAIT_MAX;
RMQGetMsgData MyRmqMsg, RMQ_PROC;%RMQ_PROC%;
ENDWHILE0
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
