After Loaded the EIO.cgf, the Omnicore Controller is in System Failure State
Hi All,
Please:
After Loaded the EIO, the Omnicore Controller is in System Failure State.
One of the errors is shown in the picture below:
https://imgur.com/a/TujJJTP
1- And this error is regarding those lines:
EIO_SIGNAL:
Any tip about this issue?
Thank you!
3B
Please:
EIO_SIGNAL:
#7 DO Controller is in motors ON state
-Name "MotorOn_Sts" -SignalType "DO" -Device "EN_InternalDevice"\
-Access "All" -Label "162-161-7 Data[5].2"-DeviceMap "162"
SYSSIG_OUT:
SYSSIG_OUT:
#7 DO The I/O signal is set when the controller is in motors on state.
-Name "MotorOn" -Status "MotorOn_Sts"
I have other errors for more Outputs and Inputs, similar to that one.
The I/O engineering it is not yet loaded.
The EIO is the only file now into the Controller.
2- I tried to delete the file from the Controller, but I was not able to find it here:
at what folder could be?...I went into all of them.
"Controller Explorer"
Thank you!
3B
Hi All..
Any support on this would be appreciated.
Thank you!
3B
The error here is system I/O signals should be placed in the sys.cfg, and they are not.
Let's try to do that!
3B0
