After Loaded the EIO.cgf, the Omnicore Controller is in System Failure State
Hi All,
Please:
After Loaded the EIO, the Omnicore Controller is in System Failure State.
One of the errors is shown in the picture below:
https://imgur.com/a/TujJJTP
1- And this error is regarding those lines:
EIO_SIGNAL:
#7 DO   Controller is in motors ON state
      -Name "MotorOn_Sts" -SignalType "DO" -Device "EN_InternalDevice"\
      -Access "All" -Label "162-161-7 Data[5].2"-DeviceMap "162"
SYSSIG_OUT:
#7 DO The I/O signal is set when the controller is in motors on state.
-Name "MotorOn" -Status "MotorOn_Sts"
I have other errors for more Outputs and Inputs, similar to that one.
The I/O engineering it is not yet loaded.
The EIO is the only file now into the Controller.
2- I tried to delete the file from the Controller, but I was not able to find it here:
at what folder could be?...I went into all of them.
"Controller Explorer"
Any tip about this issue?
Thank you!
3B
  • Hi All..
    Any support on this would be appreciated.
    Thank you!
    3B
  • The error here is system I/O signals should be placed in the sys.cfg, and they are not.
    Let's try to do that!
    3B
