IO.cfg file not loading from Notepad ++
Hello, I'm not able to load IO changes I did using Notepad ++, Robotstudio is reporting encoding error requesting ISO 8859-1 encoding. I did this type of encoding but still same error as in link below. Any advice? Thanks in advance.
https://i.imgur.com/n57Rdet.png
  • lemster68
    lemster68 ✭✭✭
    Maybe the actual error is syntactical and this message is false.
    Lee Justice
  • Hallo, you might use ordinary windows-editor. Using notepad++, try to save with charset "UTF8 without BOM"
    matti
