How can I call a userfunction onClick with a button?
I use a button in my webapp, and I want to call a function when the button is clicked. It did not work, so I tried it again with some simple code.
The simple code that I tested on is:
<div>async () => {</div><div>&nbsp; &nbsp; console.log("Test");&nbsp; <br>}</div>
And the code on the onClick of the button is:
await UserFunction.Test()
When I click on the button, the userfunction won't run. How can I fix this?
  • Hi,
    I saw that you're trying to use `console.log` in your `UserFunction.Test`. This method prints content to the browser's console, which is suitable for viewing debug information when opening a deployed application in a browser.
    If you want to display debug information on Flexpandent, you should use `Logger.i()`, which supports printing messages like strings, numbers, and more,
    And make sure to check 'Show debug log on the tech pendant UI' when deploying the webpage.
    Thanks.
  • Thank you for the reply. I will use this logger in my code from now on.
    It still does not fix the problem with calling the`UserFunction.Test` when I press a button. Do you have a solution for this?
  • In Appstudio version 1.1.0, I get an error message when I press the button. the following popup will appear:
    Event Trigger Error<br>'UserFunction' not defined<br>
  • I have the same problem — is there already a solution for this so that the functions can be used?
  • Hi Jur,
    I could not find the problem, so I made a new project and started all over again. For some reason it works fine in the new project now. I hope this works for you too.
  • Hi Yvok,
    I have now also created a new project and it does indeed work now. Is there a way to convert the old project to a new project so that the userfunctions now work?
  • Hi Yvok, Hi Jur,
    I'm experimenting the same problem with a project, created with AppStudio 1.0.0 and now edited with 1.1.0. I've also created a new project on 1.1.0, same problem.
    Have you found the reason behind this error?
    I tried with a very very simple Add function (the same shown in documentation userfunction).
    It turns out that:
    • Using Chrome to open the App, no problem. calling UserFunction.Add(1,3) -> gives you 4.
    • On the ABB FlexPendant, prints "Event trigger error". Looks like userfunction is not defined.
    Calling console.log('UserFunction.Add is defined:', typeof UserFunction.Add === 'function');
    On Chrome print TRUE, on flexpendant doesn't print anything.
    It seems the pendant runtime isn’t injecting my project.js top-level function declarations into the UserFunction namespace.
    Have you encountered this, or do you know what might be causing it? Any pointers would be much appreciated.
    Thanks,
    Filippo
  • I’ve even tried invoking the UserFunction after the entire app has loaded —using a button’s onClick handler— but it still fails.
  • Hi Yvok, Hi Jur,
    It turns out that:
    Have you tried setting the flexpendant to use the Chromium browser?
    https://forums.robotstudio.com/discussion/14742/enhance-your-flexpendant-web-application-experience-switch-to-chromium-mode
