Things to add in Appstudio
Things to add in Appstudio:
1. Group function to link buttons or images together.
2. Ability to choose corner rounding. If you place 3 buttons next to each other, you can apply rounding, but you don’t want it on the middle button, and you want the two outer buttons to have rounding only on one side.
3. Dropdown menu that stays open after clicking,allowing you to adjust parameters. If there are more tabs open, it should shift accordingly. The link what this component: https://images.app.goo.gl/9Hh1HCRZwVfzkcju5
  • 4. In the function tab a way to rename functions.
  • 5. In a button, you can use show & disable, but in an image, that's not possible. Could this also be added?
  • Great suggestion! We’ve got it, thanks!
