Pack&Go file not letting me make changes to the RAPID code?
bran21
Hello, I shared a RAPID P&G file with my other computer, and it won't let me edit the RAPID code now? Why is this? Anyone know of a fix? The 'Request write access' is greyed out and any time I save my changes it never actually saves them.
I'm on RS 2025.2.
I'm on RS 2025.2.
Is the option premium licensed on this other computer?0
You don't have to 'Request write access' on a virtual controller.Systemintegrator - Web / C# / Rapid / Robotstudio
KennyJiang said:Is the option premium licensed on this other computer?0
Have you tried to use 'Apply - Apply changes' or 'Apply - Apply all' button under 'RAPID' ribbon?
I think there is only a 'save' button to save the entire RS project, but not a 'save' button for saving RAPID change. I will have a popped up window to select a location when using 'Ctrl+S', yet to save RAPID I use 'Ctrl+Shift+S', which is the hot key for 'Apply all'.1 -
You are correct! 'Apply' was the button I needed to click to save my code changes, located under the RAPID tab --> Controller --> Apply. I wouldn't have thought the Apply button to be the one I needed to click, so thank you for your help!0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 29 AppStudio
