Things to add in Appstudio
                    Things to add in Appstudio:
3. Dropdown menu that stays open after clicking,allowing you to adjust parameters. If there are more tabs open, it should shift accordingly. The link what this component: https://images.app.goo.gl/9Hh1HCRZwVfzkcju5
                        1. Group function to link buttons or images together.
2. Ability to choose corner rounding. If you place 3 buttons next to each other, you can apply rounding, but you don’t want it on the middle button, and you want the two outer buttons to have rounding only on one side.
            4. In the function tab a way to rename functions.
            5. In a button, you can use show & disable, but in an image, that's not possible. Could this also be added?
            Great suggestion! We’ve got it, thanks!0
            6. It would be nice to be able to modify id of the graphic elements. Now if you will add custom component and id in it will be doubled in app it will not work correctly.
 7. There is no space to add global objects/methods and call them in a way that It will be available and running for the whole app all the time. Not only on some event. I mean that i would like to for example read some file and have some possibility to have access to the content from all components, not only locally where i was reading file. It is troublesome because filestream is limited on the robot controller and if you are using it also in the RAPID it can corrupt files.1
            @Jur148. Thank you for nice advice. It is nice that there is a way to modify objects Id's, but in the end it require a little higher coding skills. For now it sound more like workaround. I also found that localstorage is working on the flexpendant so this can be used as persistant, global memory (I do not know what is the limit for it so probably if there is no internal memory clearing mechanism it can be dangerous for flexpendant).
            8. Prouduce an error when deploying an application with linked variables that contain "åäö" or other unsupported characters linked from RAPID. The deployment succeeds, but the variables will only change value after the application has been closed and reopened.
 It’s a minor issue, but I’ve learned it the hard way..0
            9. Can a function be created in the component view to hide certain components? This is especially useful when placing multiple components on top of each other.
            10. It would be interesting if you could change the name of the components. Instead of using the default names (Select_110, Input_45, etc.), this would make the program easier to understand.
 Jorge Turiel0
            11. A component for tables, where you can specify the number of columns and rows yourself.0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
